Tipuri cutii automate pe Jeep
  • Tipuri cutii automate pe Jeep
    Jeep Automatic Transmission Guide
    A summary of the automatic transmissions used in various Jeep vehicles.
    42RLE: Four-speed automatic transmission was available from 2003 to 2006 Jeep TJ Wrangler with 4.0L engines. Gear Ratios: 1st Gear: 2.84: 1, 2nd Gear: 1.57: 1, 3rd Gear: 1.00: 1, 4th Gear: .69: 1
    45RFE: A four speed automatic transmission was used in 1999 Jeep Grand Cherokees with 4.7L engines. Gear Ratios: 1st Gear: 3.00: 1, 2nd Gear: 1.67: 1, 3rd Gear: 1.00: 1, 4th Gear: .75: 1, Reverse Gear: 3.00: 1
    46RE: A four speed automatic transmission was used in 1998 Jeep Grand Cherokees with 5.9L engines. Gear Ratios: 1st Gear: 2.45: 1, 2nd Gear: 1.45: 1, 3rd Gear: 1.00: 1, 4th Gear: .69: 1, Reverse Gear: 2.20: 1
    44RE: A four speed automatic transmission was used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1.00 : 1, 4th Gear: .69: 1, Reverse Gear: 2.20: 1
    42RE: A four speed automatic transmission was used in 1993.3 to 1998 Jeep Grand Cherokees with 4.0L engines. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1.00: 1, 4th Gear: .69: 1, Reverse Gear: 2.20: 1
    46RH: A four speed automatic transmission was used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines. Gear Ratios: 1st Gear: 2.45: 1, 2nd Gear: 1.45: 1, 3rd Gear: 1.00: 1, 4th Gear: .69: 1, Reverse Gear: 2.20: 1
    32RH: A three speed automatic transmission was used in 1992 to 1995 Wrangler with 4.0L engine and it continues to be used in 1997-2002 Wrangler with 4.0L engine. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1: 1, Reverse Gear: 2.03: 1
    30RH: A three speed automatic transmission was used in 1992 to 1995 Wrangler & 1992 to 1996 Cherokee with 2.5L engine. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1.00: 1, Reverse Gear: 2.03: 1
    AW4: A four speed automatic transmission was used in 1987 to 2001 Jeep Cherokee (XJ), & Jeep Comanche with 2.5L & 4.0L engines. It was also used in 1987 through 1992 Jeep Comanche & 1993 through 1993.5 Jeep Grand Cherokee with 4.0L engines. Gear Ratios: 1st Gear: 2.80: 1, 2nd Gear: 1.53: 1, 3rd Gear: 1.00: 1, 4th Gear: 0.75: 1, Reverse Gear: 2.03: 1
    TF727: A heavy duty 3 speed automatic used in full sized Jeeps (SJs and J series pickups) from 1980-1983. From 1984-1992 it was only used in these trucks with the AMC 360 V8. Gear Ratios: 1st Gear: 2.45: 1, 2nd Gear: 1.45: 1, 3rd Gear: 1.00: 1, Reverse Gear: 2.00: 1
    999: A medium duty 3 speed automatic used in CJs from 1980-1986. It was also used in 1984-1990 SJs and J pickups with the 4.2L engine, in the YJ from 1987-1991 with the 2.5L and 4.2L engine, and in the XJ and MJ through 1986. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1.00: 1, Reverse Gear: 2.03: 1
    904: A light duty 3 speed automatic used in CJs from 1980-1986 only with the I4 engine. It was also used during this time period with XJs and MJs with the I4 and V6 engine. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1.00: 1, Reverse Gear: 2.03: 1
    909: The 909 is a 904 transmission with a lock-up torque converter. Gear Ratios: 1st Gear: 2.74: 1, 2nd Gear: 1.54: 1, 3rd Gear: 1.00: 1, Reverse Gear: 2.03: 1
    Ultima editare de alin-jeep; 02.apr.2017, 09:04.
    Re: Tipuri cutii automate pe Jeep
    Stii, cumva, rapoartele de multiplicare ale convertoarelor de cuplu? La Jeep , sau la altele.
    Ma intereseaza pt. o comparatie cu masinile cu reductor.
    Sa cunosti, sa vrei - vei putea face !
      Postat în original de ctinu Vezi post
      nu am inteles ce vrei sa spui . Poate te ajuta asta :
      http://www.e-automobile.ro/categorie...zor-cuplu.html
        Convertorul de cuplu de la transmisiile automate este, in fapt, echivalentul ambreiaj+reductor mecanic de pe masinile cu cutie de viteze manuala. Spre deosebire de reductor, convertorul de cuplu este actionat hidraulic, continuu si automat, in ultima instanta, de pedala de acceleratie.
        In exemplul din linkul tau, convertorul multiplica cuplu de 2,14 ori. Stiu ca pentru automobile, in functie de destinatie, acest raport variaza intre 1,8 si 3, sau chiar mai mult.
        Intrebarea mea, sugerata de postul tau si o discutie de pe forum era: stii (sau poti indica o sursa) care este acest raport pt. Jeep, sau alte masini cu veleitati de teren pt. a face o comparatie cu cutiile manuale, cu reductor?
        Ultima editare de ctinu; 05.apr.2017, 15:49.
          Eu unul n-am gasit informatii legate de raportul de multiplicare. Mai degraba gasesti informatii legate de stall speed. Si chiar si stall speed e influentat de greutatea masinii si motor
          Oricum raportul de multiplicare scade pe masura ce se invarte axul de intrare a cutiei.
          '02 WG CRD - EGR delete
          • #6
            Ai dreptate; in faza de stall speed se manifesta, de obicei, efectul maxim de multiplicare a cuplului, care depinde de sursa de putere (motor) si sarcina (greutate, teren etc.). E normal sa scada pe masura ce motorul/forta de tractiune incepe sa depaseasca sarcina/rezistenta la inaintare.
            Daca ai asemenea date, sunt interesat.
            Ultima editare de ctinu; 06.apr.2017, 18:46.
            • #7
              Raspunsul meu :
              nu stiu ,nu ma intereseaza si nici nu ma va interesa niciodata (teoria) in schimb practica spune ca azi am reusit sa fac sa functioneze combinatia :motor Vw 1,9 tdi ARL 150 cp resoftat + cutie automata AW4 +punti portale Volvo C303 + roti 37" pe o tubulara de extrem
              P.s. In teorie il las pe @ssrli sa se descurce
              Ultima editare de alin-jeep; 06.apr.2017, 23:22.
              • #8
                Doar din ce am gasit cotrobaind pe net:
                AW4 dupa 4.0: 2100 rpm
                42re si 46rh dupa V8-uri in ZJ: 1800 rpm.
                • #9
                  Multumesc @ssrli.
                  Probabil e vorba de turatiile de cuplu maxim (2100,1800). Ma interesa raportul de multiplicare a cuplului (functia de "reductor").
                  • #10
                    Multumesc @ssrli.
                    E vorba de stall speed.
